sarapul13
phone cameras don't work
Mon Jun 06, 2016 12:34 pm
in case of switching on of cameras on phone there is a message that the camera is occupied it is necessary to close the applications using it (all applications were closed) the camera it is possible to include tolkopr reset of settings to factory parameters.
Re: phone cameras don't work
Tue Jun 07, 2016 7:53 am
Maybe a software problem. you can choose to a reboot to see if problem can be solved.
if still can not, can try a factory reset!
Best regards,
Admin
