war_horse
launcher 3
Thu Aug 31, 2017 6:19 am
going through Settings after update i can0t find the launcher (Settings--apps--launcher 3--storage--clear data and clear cache) but if i go inside app menu options i find that the app home is launcher 3, so it is installed, actually as launcher im using nova and i have done this after the update Settings--apps--nova--storage--clear data and clear cache is this the same for a correct update?
dhamokk
Re: launcher 3
Sat Sep 02, 2017 10:24 am
I might be wrong, but since the update won't touch any 3rd party apps, you don't need to clear the cache and data of Nova Launcher.
To see the Launcher 3, you have to enable "show system apps" (may be called somewhat different in english, I'm german), in the upper right corner menu.
war_horse
Re: launcher 3
Sat Sep 02, 2017 11:16 am
thank you very much dhamokk!!!!, i ve find the menu you suggested to me, and finally i can see it! the funny thing is that i ve give a look to that menu many times, four eyes are better than two :lol: :lol:
