French
can't download last update
Fri Jun 03, 2016 6:51 pm
Hi.
Phone can't download last update - Error mount SD card. Screenshoot attached.
Re: can't download last update
Wed Jun 08, 2016 7:59 am
French wrote:
Hi.
From the feedback of some customers with the same problem with you, suggest a factory reset to see if the problem
can be solved.
Best regards,
Admin
