Yuri177245
[SOLVED] New copy duplicated
Tue Aug 29, 2017 11:22 pm
Hello, every time that muy smartphone Android and its a good smartphone Blackview BV 8000 pro turned off, when I Will on again have duplicated 8 ir 6 app that I have instale on It un the main principal view of the screen. What can I do for resolve this trouble.
Re: New copy duplicated
Fri Sep 08, 2017 2:37 pm
Do you use the latest firmware 20170829?
If yes and a firmware don't help try to use an other launcher from play store.
