bot4
BV7000pro water problems
Tue Aug 29, 2017 9:26 am
i get something liddle bit water inside my bv7000p, but it works normaly firstly.
after 2 days the touchscreen make something problems, but not the complete screen.
i ordered an new toucscreen on aliexpress, for my bv7000p.
after installed the new screen and it turns on, the screen works, but without any touch, touch dont work all over the display.
how maybe it the problem?
how can i get my phone data on pc without touch work?
iam so worry about, the phone is very cool, but not for me :?
thanks for helps!
Re: BV7000pro water problems
Tue Sep 12, 2017 5:16 pm
Always close the seals in wet surrounding.
you can connect a compter mouse over otg-cable to make inputs and save your data.
