Pepepalotes
External speaker doesn't work!
Mon Aug 28, 2017 11:52 am
I started the phone for the first time with any problem, cameras ok, screen ok, wifi ok... ETC.
But when I tried to listen music, youtube, alarms, nothing sound. Volume totally up, not disturb mode off.
Re: External speaker doesn't work!
Mon Aug 28, 2017 2:15 pm
Do you mean the internal speaker on the backside?
For external speaker over jack connection be sure that you may need a longer plug.
