hawgie
Hyper sensitive screen.
Sun Aug 27, 2017 10:08 am
Hi Iv'e recently purchased this phone and I'm having a problem with the touch screen. It is really too sensitive, while scrolling it selects items by itself, or when writing on the keyboard it presses adjacent letters.
Under Language keyboard > pointer speed I've set the slider to the minimum, it has helped a lot, in the default setting my fingertip was being detected from 5mm away! But it isn't enough, is there anything else to set? I've flashed the latest ROM and reset 2 times.
Please help it is very frustrating to use like this.
Thanks
Re: Hyper sensitive screen.
Tue Sep 12, 2017 3:50 pm
I will ask our technician about this. Until further respond keep your firmware up to date to test if updates already solved that.
