lorizisback
Proximity sensor not working - calibration failed!
Fri Aug 25, 2017 12:14 pm
I have a bv8000 pro updated to last version.
The proximity sensor isn't working: in call, screen becomes black and stays black after the call.
Every sensor app says I'm always close to the phone.
In Engineering Mode, I tried doing the calibration but always says "calibration failed".
Any ideas?
Re: Proximity sensor not working - calibration failed!
Fri Aug 25, 2017 2:53 pm
I will ask our technicians about this.
lorizisback
Fri Aug 25, 2017 4:22 pm
Thank you for the quick answer. Tonight I'll try to factory reset the phone and I'll post the results.
lorizisback
Fri Aug 25, 2017 4:50 pm
A little more detail that could be interesting:
the reading of the proximity sensor in Engineer Mode is always 255, except for an instant sometimes.
Sometimes, for just an instant (way less then half second) it reads a value.
The light sensor (which i believe is on the same circuit) works correctly.
ABnormall1993
Fri Aug 25, 2017 9:42 pm
I've got the same problem
jmi81
Sat Aug 26, 2017 6:35 am
Did you set min and max values before do calibrate?
Doing that works for me.
lorizisback
Sat Aug 26, 2017 6:58 am
I tried but it always reads the maximum value. Doesn't work.
Thank you though
lorizisback
Tue Aug 29, 2017 7:19 pm
Any news?
burg3r
Wed Aug 30, 2017 4:19 am
I had the same problem. After I reset the calibration it worked. After that in engineer mode it worked perfect.
I hope this help u guys
admin
Site Admin
Wed Aug 30, 2017 6:12 am
In the dialing interface, input the *#87#*, and try to test the calibration. If you success, there will be a "pass"; If not, you should change another sensor.
