oaimng
[SOLVED] New update 20170822 small issue
Fri Aug 25, 2017 8:23 am
I updated to 20170822, back up and restore app seems to be missing, and when I keep home button tapped, instead of showing me background apps that i previously opened, it opens google search, i can't see any setting to get back to showing last used apps, can someone please let me know how can I set the home button back to it's background apps function?
yaya
Re: New update 20170822 small issue
Fri Aug 25, 2017 8:34 am
YOU CAN SHORT PRESS THE MENU KEY IN THE LEFT AND THEN WILL SHOW APPS USED RECENTLY.LONG PREES THE MENU KEY WILL SHOW WALLPAPER SETTING.
marceloj.bueno
Fri Aug 25, 2017 10:26 am
Quick click on the button = the left of the |ˆ| There it will show the applications in the background.
Fri Aug 25, 2017 2:37 pm
@yaya @marceloj.bueno thank you for helping!
paulies
Fri Aug 25, 2017 7:33 pm
Least Android pay works now :D
Shame the back key is still not working so good.
Thanks Paul
schiaucu
Fri Aug 25, 2017 11:00 pm
The update 20170822 does not solve the camera issue, the phone is still taking blurry images.
shahardemos
Sun Aug 27, 2017 4:19 am
In my case the update from the 22nd did improve a lot on the main camera status. SOME of the pictures are sharp. Some still blurry. At least you can take a snap, check it, if not sharp enough try to take it with manual focus. It is not consistent, but at least one out of few is very sharp with enough details that you feel it is not a 2MP camera anymore...
zimzia
Sun Aug 27, 2017 8:43 am
Backup and Restore app missing ?
ronald111
Sun Aug 27, 2017 10:14 am
another one I tried, there is no google assistant.
when i said sing a song before, google assistant would sing a song for me, but in this update, google only search whatever i say.
Latsi
Sun Aug 27, 2017 1:38 pm
Wireless Update
Current:
BV8000Pro-Blackview-V0.1_20170803_20170822-1836
Network connection failed(timeout)
XXX
After last update, it's network connection failed.
What now please?
Users browsing this forum: WeraziMUH and 2 guests
