iwars71
bv 6000 restarts
Thu Aug 24, 2017 4:24 pm
Hello! Some time ago I bought the BV 6000, I'm very pleased with this handset, I like it all and I'm happy with it, and I even have this exclusive version with the version of Android 7 But for some time now he lives his own life, restarts when and how much. Often wants, sometimes in a conversation, sometimes even on a shelf. It would not be a problem if i could this phone with that file defect back to the seller, but I've lost contact with the vendor. I live in Latvia, but there is no representation or service center here.
Can you give me some help what to recommend?
Re: bv 6000 restarts
Tue Sep 26, 2017 7:28 pm
update to the latest Firmware and perform a factory reset in recovery after that.
grAwp
Fri Sep 29, 2017 6:03 am
I have almost same problem listed here : viewtopic.php?f=142&t=319131.
Users browsing this forum: No registered users and 10 guests
