MB242
WI-FI 5GHz - it is supported?
Thu Aug 24, 2017 6:15 am
can someone please confirm that 5GHz wi-fi works on his/her phone?
BV8000pro cant see any of 5GHz SSID around.
Re: WI-FI 5GHz - it is supported?
Thu Aug 24, 2017 8:30 pm
Yes, it is supported. Notice that 5GHz Wifi may have a smaller possible distance (for all devices) than 2,4GHz.
MB242
Fri Aug 25, 2017 6:07 am
The issue is the hidden SSID. While i can connect to 2.4GHz SSID, 5Ghz is a taboo for BV8000pro. Other 3 devices (Dell laptop, oneplus 3 and 3T) I can easily connect to 5GHz hidden SSID.
Fri Aug 25, 2017 2:50 pm
Thanks for the feedback. I will report this.
Can you try this: update to the latest Firmware (today its 20170822) and perform a factory reset in recovery after that.
MB242
Fri Aug 25, 2017 2:57 pm
Already did factory reset with the latest rom installed. It didn't help.
Matioupi
Sun Aug 27, 2017 9:48 am
Is there a way to check which regulatory domain the phone is using for WiFi ?
