javifanjul
VOLUME BUTTONS DO NOT WORK
Tue Aug 22, 2017 12:59 pm
Hello, I used the phone in a pool and I put it 50 cm under the water, when I removed it from the pool, the phone started to go crazy, and the volume buttons were raised alone, until they stopped working. Does the warranty cover in Spain, if I bought it outside? any solution?
Hola , el telefono lo use en una piscina y lo meti 50 cm bajo el agua , al sacarlo de la piscina , el telefono empezo a volverse loco , y a los botones del volumen se subian solos , hasta que han dejado de funcionar . Lo cubre la garantia en españa , si lo he comprado fuera ? alguna solución?
Re: VOLUME BUTTONS DO NOT WORK
Tue Sep 12, 2017 3:44 pm
for questions about warranty please contact your seller.
