Good morning, I write from Italy and I'm sorry for the language .
I just bought this smartphone, and by using it, I realized that this problem:
The internal memory is 2 GB instead of 16 GB, so very few applications by installing the internal memory is insufficient.
I reported several times on the phone to Factory settings but not change anything.
By installing the application Diskinfo, it is that a partition of 11GB called "intsd" unmounted.
Is there anything I can do to avoid bringing the smartphone support?
Sincerely Nicola
