mbrobich1966
[SOLVED] Love this phone !!
Sat Aug 19, 2017 12:42 pm
Just wanted to thank you for this phone !!. My friend had a BV6000 and he loved it. He had a few bugs with it(mainly texting), so I waited to get an updated one. This for me is the needed update and the best TOUGH phone on the market. I am in Canada and use 2 sim cards, Bell and Rogers. So a dual sim phone was a necessity. Also the extra SD memory slot as I have a 128GB card full of music. Although it only worked when formatted in FAT32(usually says corrupt SD card)
The speaker for music is awesome. Probably one of the loudest on the market.
The camera is really good. I like how sharp the i mages are.
Bluetooth works great so far. I boought a $10 smart watch from Gearbest and it syncs and makes calls no problem !
Pretty much the only bug I find is the lack of HOME screen control. I cannot make extra screens and cannot move icons like I want too..
Is there going to be an update to his control soon ??
Targun
Re: Love this phone !!
Wed Aug 23, 2017 12:44 pm
Cool. Try connecting any decent headphones to it then..
Thu Aug 24, 2017 8:13 pm
You can install an other launcher app from the play store.
Mamay
Fri Aug 25, 2017 5:37 am
Where can I download the driver for connecting the smartphone to the computer? My Win10 does not see bv8000pro when you connect.
Fri Aug 25, 2017 2:40 pm
VCOM driver – https://www.google.com/search?q=MT67xx+USB+VCOM+DRIVERS Install the drivers. Restart the Computer after Driver installation. Check Windows Device Manager to be sure Driver is installed correct. Use original cable.
schiaucu
Fri Aug 25, 2017 11:14 pm
That means someone can take good photos with this phone? Cool! Seems that the company should recall all the phones who takes shitty pictures.
Users browsing this forum: Google Adsense [Bot] and 2 guests
