petat
Over sensitivity display and BT Parrot device
Fri Aug 18, 2017 1:31 pm
Hello
I have BV6000S with Android 6 about half year.
BV6000S+_Blackview_V01_20161021
1) I have problem with oversensitivity of display.
When I hold phone in my hand all is relative OK, but when I put phone o table an click only o display
phone is uncontollable.
Is it hardware or software problem?
2) I have also problem with my car BT device Parrot. This my mobile is not able to work with this device.
I found some similar information about problems with Android 6 with this device.
https://community.parrot.com/t5/Minikit ... d-p/128466
Can You help me?
Thanks
Re: Over sensitivity display and BT Parrot device
Mon Oct 23, 2017 12:47 pm
Update to the latest firmware: 20170930
If it don't help try a factory reset after that.
Users browsing this forum: Google Adsense [Bot] and 0 guests
