megalift
[SOLVED] Selfie (front) camera doesn't work on brand new BV8000
Fri Aug 18, 2017 12:10 pm
I've tried posting this once already.
The front camera on my new BV8000 doesn't work. At all. No app can start the camera, I just get a 'camera not available' message.
I did a factory reset as this appears to be a recommended first Port of call for most problems, but no change. I've downloaded the firmware for the camera but don't really want to reflash the phone until I've heard what others have to say - does anyone have any suggestions?
Re: Selfie (front) camera doesn't work on brand new BV8000
Thu Aug 24, 2017 8:17 pm
If nothing helps you can exchange the device over your seller.
svenhernot
Tue Oct 10, 2017 4:16 pm
same problem with my bv8000 :(
Dalmo Jr
Tue Oct 10, 2017 7:40 pm
Same with my BV8000 PRO. Front camera doesn't work even after factory reset :(
Fri Oct 13, 2017 12:18 pm
I will report that issue but it sounds like an hardware bug. You could open your phone and watch if the connection is correct or you could exchange it over your seller.
