Simple Flashing Tutorial
Fri Aug 18, 2017 10:17 am
In the PDF file below is a simple flashing tutorial for BV7000.
Before you start flashing, please make sure you have understand clearly about this operation and you can do it.
flashing-BV7000_v4.pdf
(374.58 KiB) Downloaded 3640 times
PietK
Re: Simple Flashing Tutorial
Wed Sep 13, 2017 8:17 pm
Dear Admin,
thanks for your new tutorial-V4, but . . . . the picture shows wrong Flashing-data (copy of the BV7000-PRO tutorial). It shows incorrect CPU and incorrect scatter-file. This is the BV7000 section with Tutorial for BV7000 not for the PRO as mentioned on the first line of the Tutorial.
Please update to V5, so we know what we should see when starting to flash.
Best Regards.
Wed Sep 20, 2017 5:22 pm
You are right, the screenshot is made wile flashing an other phone but the tutorial and all links are absolute correct for the BV7000. Scatter file will be different in every version, we will not write a new tutorial every time for that.
