apelsin
BV5000 do not support G3 and G4 internet service in Latvia!
Fri May 27, 2016 4:04 am
Dear Admin! My BV5000 do not provide internet connection in G3 or G4 using any internet explorer in Latvia even G3/G4 signes are shown as turned on and available in the top bar! This problem was as on Android 5, as on Android 6. Other apps such as Market, GPS application MAPS, Facebook, Messanger works normally. Internet explorer using is available usind Wi-Fi network connection. I have check everithing and tried SIM cards changing fisically and in properties, changed a lot of other properties, but have no result. As I see many other BV5000 owners also have same problem. Please, please, deaer Admin, if it is possible, make some patch to correct this amazing phone's "brains" in a month! Other way BV5000 will have bad reputation in Latvia and I am affraid I would be the last, who bought it in our country ...
Re: BV5000 do not support G3 and G4 internet service in Latvia!
Fri May 27, 2016 6:15 am
before you choose this model , have you checked if the network frequence are suitable in your local ?
Best regards,
Admin
