jonnyklf
Cell data and wifi turns off by it's self
Fri Aug 18, 2017 8:44 am
On my BV6000 after I turn on the cell data internet it turns off by it's self the same with Wifi after the last update:
kernel version: 3.18.35, root@ouyang #6, Sat Jul 8 13:49:32
baseband version: MOLY.LR11.W1603.MD.MP.V35.4.P26 2017/07/06 15:45
Can you help me?
thank you
Re: Cell data and wifi turns off by it's self
Fri Aug 18, 2017 12:40 pm
I will report this. Please try if this helps:
