ardrezt
Touchscreen touble
Fri Aug 18, 2017 5:26 am
Please help..
I have used all the rom nothing works,
Touch screen went crazy...
What is this driver error?
frofa
Re: Touchscreen touble
Thu Nov 02, 2017 10:11 am
try to flash the latest ROM, it solved quite a number of problems for me, including the capacitive button problem. And the touchscreen works fine, too, although maybe a slight bit too sensitive (but no problem for me really).
b.mihai.89
Tue Nov 07, 2017 3:39 pm
If you have trouble i would recommend that you perform a factory reset before and after flashing.
Use recovery for this.
Tue Nov 07, 2017 7:01 pm
Thank you for helping!
