borisedu
Change in the lower tactile buttons
Thu Aug 17, 2017 9:11 am
hi
Since I've updated to 20170708 firmware the buttons below have changed use. The problem that I have that the button of the three lines no longer opens the settings. How can you change the use of the button to open the settings of the applications instead of what you do now?
thanks you
Re: Change in the lower tactile buttons
Thu Aug 17, 2017 7:50 pm
Softkey assignment had to be exchanged for receiving certification. It's now the same like at other smartphones. I suggested that the keys can be changed free by users in next versions but I am not sure if it is possible. I know this is difficult to get used to this change. You could use an older ROM in the meantime if you prefer that.
