toni10
bought from amazon with a trojan screen fragile
Wed Aug 16, 2017 12:58 pm
It came with a trojan and need reinstall by hand the android. After 5 months it falldown from my bedroom table and screen and LCD broken, absolutelly destroyed, red, white and bluelines, no image.
Any solution?
WhatsApp Image 2017-08-16 at 14.34.07.jpeg (187.72 KiB) Viewed 6565 times
Re: bought from amazon with a trojan screen fragile
Wed Sep 27, 2017 11:49 am
- good to hear you could remove the maleware, some bad (re)sellers may do it on their phones
- you can buy a cheap new display on aliexpress: https://www.aliexpress.com/af/bv6000s-s ... isViewCP=y I recommend a complete front uni not only the lcd or touch unit because that is easier to exchange.
