Strellok
P2 lite display flickering during phone call or bad signal
Thu Aug 10, 2017 9:53 am
Hello, I have problem with display flickering, blicking and turning off especially when mobile signal is low or while I am calling. This problem remains from the beginning. I tought that android update solve this issue but unfortunatelly, update did not solve it. Is there any possibility how to solve above mentioned problem? Thank you for advices.
Re: P2 lite display flickering during phone call or bad signal
Thu Aug 10, 2017 7:06 pm
update to the latest Firmware 20170622 and perform a factory reset in recovery after that.
