exander
logo.bin - format/tool
Wed Aug 09, 2017 4:27 pm
Is there a logo.bin format specification or tool to work with the file?
I would like to create custom logo for my phone.
Re: logo.bin - format/tool
Thu Aug 17, 2017 8:01 pm
can not give official help for that kind of changes.I moved the thread to user sharing. Maybe a user xan help you.
exander
Thu Aug 17, 2017 10:50 pm
Already figured it out. Had to write the code te extract & repack logo.bin myself.
If anybody is interested I can now make a custom boot screen (custom logo.bin file) for most of the Mediatek based Blackview phones I think. It can be easily flashed by SP Flash Tool.
Fri Aug 18, 2017 1:03 pm
Thanks for your feedback. Feel free to post a tutorial to help other users.
mikebv6
Sun Aug 27, 2017 10:46 pm
I would lie to know how to change my logo
thanks
exander
Sun Sep 03, 2017 3:29 pm
you need SP Flash Tool and then modified logo.bin file. If you know what image you would like to put on the boot logo screen, send it to me int 720p resolution and I can prepare logo.bin file for you.
mikebv6
Mon Sep 04, 2017 8:44 pm
Thx, what's the soft you use to extract or compress logo.bin ? And do you have a simple solution to remove the small animation just after start up on how to remove sim's back cover ?
exander
Wed Sep 06, 2017 7:27 am
You don't need to extract logo.bin at all, you can just take the file from the firmware package. Software for this version is not available anywhere, so I have to write my own, not yet public, but I can build you logo.bin file for you If you send me image.
Boot animation is part of the system and you can change it by this tutorial: http://www.hongkiat.com/blog/change-and ... animation/
What do you mean by SIM's back cover?
mikebv6
Fri Sep 08, 2017 8:08 pm
You know each time you restart the phone you got a little animation that's showing how to remove back cover. I would like to remove it...
Users browsing this forum: Google Adsense [Bot] and 4 guests
