prascho
Cannot Enter Developer Mode
Tue Aug 08, 2017 9:58 pm
After I updated to the latest ROM - BV8000Pro_blackview_20170804 I cannot enter Developers Options anymore - I constantly get the following error message:
"Settings keeps stopping"
X Close App
I need to enable the USB Debugging and there is no other way to do this but in the Developer options. Please, advice how to fix this!
Re: Cannot Enter Developer Mode
Fri Aug 11, 2017 8:50 am
please try if a factory reset will help to solve this:
prascho
Fri Aug 11, 2017 1:32 pm
I tried this several times with no success unfortunately. I am still not able to enter developer mode.
