Craigw
@Outlook.com Email crash
Tue Aug 08, 2017 2:42 pm
Hi, I've just unboxed my new BV7000 and, while I love it, I cannot get my email configured on the native Android email app.
It works fine if I add my @gmail.com account *but* the moment I try and add my @outlook.com account (my main email account), I get the "Unfortunately, email has stopped" message.
I've tried all the usual suspects like checking for updates, clearing the email cache, even deleting my Google account but I'm still stuck with the problem.
Any ideas most appreciated
Craig
Re: @Outlook.com Email crash
Thu Aug 10, 2017 7:02 pm
A) Use an other email APP from play store
Or B) update to the latest Firmware and perform a factory reset in recovery after that.
Craigw
Sat Aug 12, 2017 9:50 am
Dear Admin, thanks for suggestion. Am currently using the outlook android app to get my @outlook email. Will try the factory reset when time allows and will update here as to its success or not.
Kind regards, Craig
Mon Aug 14, 2017 4:22 pm
Marco-66 wrote:
Craigw wrote:
blackview_admin wrote:
Same problem here ... --> viewtopic.php?f=175&t=240684
I don 't want to make a factory reset .... We want that the APP is running well !
You wrote about the outlook-app, Craigw about the native email app. Two different things, right?
