decayedsin
How to Rollback to Android 5.1 Manually - Answer (Using Flash tool, Less faulty version is v1.5)
Fri May 20, 2016 1:59 pm
How to rollback to Android 5.1 is follow the instructions from their supplied link but delete the "checksum.ini" file inside the folder because it is incorrectly configured. By just deleting the "checksum.ini" file, then it is possible to use the flash tool to go back to Android 5.1.
Manual flash link:
viewtopic.php?f=96&t=1027
maneex
Re: How to Rollback to Android 5.1 Manually - Answer (Using Flash tool, Less faulty version is v1.5)
Fri May 20, 2016 4:29 pm
And one addition to previous guide:
Win10 gives couple of errors if 'rom'.zip is extracted using Windows own filemanager and if tried to install anyways, installation will fail.
But when extracted using 7zip ROM-package extracts without errors and can be installed safely using previous method.
saniabaltiec
Fri May 20, 2016 7:19 pm
Если после обновления до 6,0 возникли проблемы с зарядкой,попробуй зарядить батарею зарядкой малой мощности 600ma.shurik-57@mail.ru
AustrailianBlackview
Sat May 21, 2016 1:22 am
Does anyone knowbif you need root access to flash the previous version?
ehquionest
Sat May 21, 2016 6:14 am
No you don't need !
