zimzia
[SOLVED] 20170718 Local Update to 20170804
Mon Aug 07, 2017 6:14 pm
After Local Update to 20170804 from 20170718 Android does not update, OTA does not find any updates ?
Why is that?
Re: 20170718 Local Update to 20170804
Tue Aug 08, 2017 12:54 am
Why is that?
OTA sometimes doesn't work, you have to get the zip provided on the forum then local flash or use Sp Flashing Tool to get the newest update
zimzia
Tue Aug 08, 2017 4:46 am
Local Update not work, android updated but still is 20170718 :(, does the sd card have to be on the phone?
JiullJuinn
Tue Aug 08, 2017 11:50 am
Local Update 2 hours, android updated but still is 20170718
jmi81
Wed Aug 09, 2017 4:35 am
Mine is the same, still showing 20170718
viky
Wed Aug 09, 2017 7:13 pm
Same issue here, local update from 20170718 to 20170804 does not work, OTA for 20170804 was never offered.
Are there any chances to get new firmware? I don't have windows PC for SPFlashTool.
Cccake
Wed Aug 09, 2017 9:57 pm
hallo
tried to update to the new 20170804 with local update, but now only getting in recovery mode. phone doesn't restart normally now. Any help please..
Thu Aug 10, 2017 7:31 pm
It seems this file is not usable for local-file-update. Only OTA + Flashing.
jimmy02000
Wed Aug 16, 2017 12:03 pm
Cccake wrote:
hallo
Bonjour
You must install the update before installing recovery mode
Cordialement
