lylou9
Proximity Sensor : calibration failed
Mon Aug 07, 2017 11:57 am
Because my screen didn't shut down during call, I tried this for my Blackview BV7000 pro by on Amazon :
Calibrate your Proximity sensor in engineer mode:
- type *#9646633# into the keypad of the phone app
- go to tab "Hardware Testing"
- open "sensor > Light proximity sensor > PS Calibration > Calibration > do calibration
But an error message appear : "Calibration failed".
Can you help me please ?
Thanks !
Re: Proximity Sensor : calibration failed
Thu Aug 10, 2017 6:16 pm
I will report this to our technicians and reply if they find a solution for you. Which Firmware version are you using?
Mon Aug 14, 2017 3:18 pm
I am sorry, with the current firmware it is not possible to calibrate the sensor, just to check if it is working.
