Hi Admin,
The A8 is a pretty good device, but I get two annoying issues.
I am unable to use GPS using apps like Maps or Waze. The strange thing is it seems to work fine when using a GPS tester.
The proximity sensor seems not to work properly. The screen is not deactivated when answering a call and putting the device on my hear.
I hope these two issues will be solved in a future ROM update.
Regards,
Grizar.
