giantG
can not turn off vibration on tap
Mon Aug 07, 2017 7:12 am
hi , I made factory reset , Room 0807, and now I can not turn off vibration on Tab, it automatically turn on about 2 minutes, no way to make it off
pls advise
giang
Re: can not turn off vibration on tap
Tue Aug 08, 2017 2:49 pm
If this don't help please flash a clean ROM.
giantG
Thu Aug 10, 2017 2:39 am
Hi thks, I did it third time and it is OK, however after 2 days working now there is problem with network data, data network is automatically turn off after about 10-15 second. pls advise, tks
Thu Aug 17, 2017 6:38 pm
Are you on the newest firmware version? Strange issues starting some days after an reset could be caused by an maleware. So be sure to keep your system up to date.
An other thing could be a to strong battery saving setting/app.
