prrdtrn
Problem with Android 6.0
Thu May 19, 2016 3:20 pm
Yesterday, i made the update of my BV5000 as proposed by the phone.
Since i have problems, the phone is slow, and the battery doesnt charge... i tried to reset the phone twice but there are still the same problems.
Maybe i can download somewhere the previous ROM wich was intalled on my BV5000 ( ROM that worked well )
Thanks for the support and the help.
Pierre
Re: Problem with Android 6.0
Mon May 23, 2016 8:38 am
if you do not mind , can wait for some time ,
i will release a new 6.0 OTA Update to improve the performance.
Best regards,
Admin
trewq2
Mon May 23, 2016 1:33 pm
Dear Admin!
I am the owner BV5000
I want to do the old original factory firmware.
I've done it, but stay in Android 6.0.
What can I do ??? Please help ...
bye
Sword76
Mon May 23, 2016 1:41 pm
Dear Sirs!
In order to release better device image please find bellow my critical bugs list:
- Slow device system reaction. That issue escalated already in many posts.
- Default Phone application screen is empty. Only dial-pad. No history calls, favorites or contact lists icons or tabs. I suppose they were in previous image versions.
- Slow or no device charging with native AC/DC adapter.
- Screen back-light not turning on during incoming calls. Power bottom need to be pressed twice to awake device.
- Theme application does not work properly. Some of themes and backgrounds could not be downloaded or applied to device. It seems to me the application is critical to network bandwidth. It is almost impossible to download large themes or image files if network connection is poor. It looks like the application has no download guarantee protocol support.
That's all were discovered in couple days of new image using. It would be very nice of you if you take in account these comments.
Please do not hesitate to contact me if you`ll have any questions.
Regards,
Sergey.
Wed May 25, 2016 7:30 am
trewq2 wrote:
Dear Admin!
bye
we have publish a flash manual and 5.1 rom,
you need to use flash tool to flash it back.
Best regards,
Admin
ehquionest
Wed May 25, 2016 10:46 am
Where ? Which link ?
Fri May 27, 2016 7:15 am
trewq2 wrote:
Dear Admin!
bye
how did you try to get back to a old original factory firmware ?
Use flash tool or just SD download upgrade ?
Best regards,
Admin
