dubiel
Proble with SIM-Card, retype the PIN
Thu May 19, 2016 9:56 am
I have a problem with the SIM-Card.
The phone is working fine with the SIM-Card.
But after some minutes I have to retype the PIN again.
Maybe the contact to the SIM-Card is lost.
After retyping the PIN it works fine for some minutes.
Do you have an idea ?
Kind regards
Rainer
Re: Proble with SIM-Card, retype the PIN
Mon May 30, 2016 7:32 am
what do you mean by refering to retype the pin?
Best regards,
Admin
