amorimmax
BV7000 Pro Stop working after fall 30cm
Sun Aug 06, 2017 4:30 pm
Hello again,
I´ve had a BV7000 pro for a month and it´s a great phone but a couple of days ago it fell and stoped working alltogether.
The fall was from about 30cm off the ground and the unit did not suffer a scrach or a dent but stoped working!!!
I´m quite disapointed since this is supposed to be a "rugged phone" and it broke down with a simple fall.
Should I open the unit? There seems to be something loose inside the unit!?
What could be the problem??
I would apreciate any help and a reply.
Best regards,
Max Amorim
Re: BV7000 Pro Stop working after fall 30cm
Mon Aug 07, 2017 8:59 pm
I guess the battery lost it's connection. you can open and fix it with this tutorial: viewtopic.php?f=175&t=151560
amorimmax
Sun Aug 20, 2017 8:14 am
Hello again,
I took the phone apart and the only thing that seems "wrong" with the unit is a cut on the black band that connects the batery to the phone.
I´m sending a picture of if.
I´m not sure how the fall could have done that but at this point I´m trying averything!
3 questions: 1 - looking at the picture, do you thing that this cut is enough to damage the batery?
2- How can I test to see if there is inturruption of voltage between the batery and the connector at the end?
3- Is there anything else I should be looking for that can cause the phone not to work?
Thank you for your help!!!
amorimmax
Sun Aug 20, 2017 8:15 am
I´m trying to send a picture but I don´t think its going...
Tue Sep 12, 2017 2:54 pm
Sorry, it's hard to help without the photo.
