moytigr
BV6000 internal speaker silent, factory restart did not help
Sun Aug 06, 2017 2:42 pm
just from one day to another my internal speaker in BV6000 (Android Version 7.0) has stopped working. No alarm, no ringtone, no media, no loudspeaker during phone call.
After trying to find the reason for that I have decided to make factory reset, but the result is still the same, built-in speaker is not working. Do you have any hints how to fix this problem.
Re: BV6000 internal speaker silent, factory restart did not help
Tue Aug 08, 2017 2:55 pm
you can ask your seller for repair or replacement or buy a new speaker buy your own.
ear or backside speaker: https://www.aliexpress.com/wholesale?Se ... earch=true
video tutorial: viewtopic.php?f=142&t=123499
Edit: with the video you can also check the speakers connection. Lift the contacts and try if this will help
