tomithyom
Alternative to Glove Mode suggestion.
Sun Aug 06, 2017 3:17 am
Blackview Admin Team... Thanks for the latest BV6000 update for May 2017, it works very well and has finally solved the capacitive button sensitivity issues. It is a real shame Glove Mode has gone because unfortunately, this is why I bought the phone in the first place. Having said that, I want to make a suggestion.
I noticed there is a screen sensitivity app for Samsung phones (see the link below). I have installed this on the BV6000 but it doesn't do anything, probably due to different hardware. I was wondering if it would be possible, and possibly a viable alternative to hard coded glove mode, to have a Blackview App which adds Glove Mode to Blackview phones. The app on the link below apparently works quiet well for Samsung phones at least and maybe others, and the only way I can get back Glove Mode (which works fine, but I didn't want it turned on all the time) for the first Android 7.0 update is to flash that version again.
Maybe an app is a great work-around here?
http://appcrawlr.com/android/sgs-touchscreen-booster
Re: Alternative to Glove Mode suggestion.
Fri Aug 18, 2017 1:01 pm
thanks for your feedback.
