khubeo
Partially non-responsive screen
Fri Aug 04, 2017 7:04 pm
Have you ever seen anything like that? Please see video:
https://youtu.be/g5YcAbvpR1I
One day I noticed I have problem choosing some items from menus if they are located at certain height from the top of the screen. I needed to scroll the menu down or up to choose those items. I never had that problem before. Then I thought of trying some drawing app, and voila. There is a stripe of screen that does not work. What do you think of that? Can I do anything about it?
I may add that nothing ever happened to the phone, like falling from some height or getting into water.
Re: Partially non-responsive screen
Tue Aug 08, 2017 3:06 pm
Update to the latest Firmware and perform a factory reset in recovery after that.
If that don't help please ask your seller for repair or replacement.
