Dave2012
Screen tearing
Fri Aug 04, 2017 7:23 am
Got a new bv 7000 and the screen tears ,some graphics pictures make the screen go black or just all pixsels drag down when scrolling any way to fix this or is it broke ?
Re: Screen tearing
Mon Aug 07, 2017 8:13 pm
update to the latest Firmware and perform a factory reset in recovery after that.
Dave2012
Re: Screen tearing
Sat Aug 12, 2017 7:26 pm
No this did not fix the problem still tears under certain graphics ,and now I have to reinstall all my apps ;-) phone works great except that ,shame my 3 rd black view and I never had any problems before .I'm currently on a boat thats why I got the water proof one so I have problems Whit getting a PC to connect it for a room update ,would a room update fix this ?
Re: Screen tearing
Mon Aug 14, 2017 4:25 pm
flashing the latest ROM (+factory reset after that) should fix it. Please report if it works for you when you are back home.
sweetpalm1966
Re: Screen tearing
Mon Aug 28, 2017 2:18 pm
Good day!
Did this fix, issue not resolved. Would be very happy to hear another fix for a unit less than 2weeks old. thanks
Re: Screen tearing
Tue Sep 12, 2017 9:08 am
sweetpalm1966 wrote:
Good day!
Latest firmware should fix it!
