Sword76
Re: Android 6 upgrade - phone seems slower than before?
Wed May 18, 2016 4:30 pm
Dear Sirs!
Is it possible to roll back to Android 5? It was my big mistake to update my hv5000 to 6.0. And your answer makes me feel that we should live with slow device because of big image. Next update may solve this issue or may be not. I was quite happy with latest Android 5. And I would like to downgrade to old version. Is it possible to download old image? Thank you.
saniabaltiec
Wed May 18, 2016 8:10 pm
Зачем делать обновления,которые ухудшают работу телефона.После обновления до Андроид 6,0 телефон стал медленнее и у него начались проблемы с зарядкой.Теперь придется возвращаться до заводских настроек,а это значит заново устанавливать все программы,которые стояли раньше.
Thu May 19, 2016 7:55 am
skulhedface wrote:
Dear Admin, the phone is not "a bit slow". It's a difference like day and night.
Now I'm stuck with a battery that won't charge over 45%. I tried everything - different cable, charger, charging while off - nothing works. It just won't charge up over 45% and it takes ages to even reach that (trickle charging?). :(
At least this time there's no hidden malware in the OS. :lol:
we feel so sorry for the problem.
We are having a internal discussion about the about. We are trying our best to improve the
performance of the new os , and any solution we will share with you as soon as possible.
Best regards,
Admin
Thu May 19, 2016 8:40 am
hori wrote:
Hi guys hope someone can help.I upgraded to 6.0 via ota but the phone wont boot it just has the blavkview logo.I only get three options in recovery mode Normal, Fast boot and recovery which comes up with dead droid and says no command.Am trying to reflash it via the tutorial here but
i cant get past the first stage.The computer fails to load the software correctly and i get my device not recognised properly.Very frustrating
can you provide any pictures or video for us to know more about the details ?
Best regards,
Admin
Thu May 19, 2016 9:41 am
Sword76 wrote:
Dear Sirs!
we really feel so sorry for the problem.
we are try to figure out the reason and try to provide a proper solution as soon as possible.
Best regards,
Admin
sprbrd
Sat May 21, 2016 9:05 pm
The proximity sensor (which turns off the screen when holding the phone to your ear) now works even worse than 5.1. Especially after 1 minute of conversation screen is turned off and does not turn on when you remove the phone from his ear. The screen can only be switched on by pressing the "Power"
Mon May 23, 2016 8:45 am
Hi ,
we will release a new OTA update to improve the performance.
Best regards,
Admin
decayedsin
Mon May 23, 2016 8:47 am
Hi, can you give us an estimated date for the new release?
Everybody with Android 6 and who does not know or does not want to risk to flash back needs this URGENT!.
makelued21
Mon May 23, 2016 9:24 am
is there anyone here had issue on BV5000 6.0? like a http://bbs.blackview.hk/viewtopic.php?f=96&t=23599 Android 6 upgrade - phone not charging anymore? except the phone become slower?
maneex
Mon May 23, 2016 10:29 am
I think none of those phones which have been uograded to 6.0 are charging normally. Tested with 5 BV5000 and all of those have same problems.
