steirx
Android 6 upgrade - phone seems slower than before?
Tue May 17, 2016 8:42 pm
Hi there,
Besides other issues, I find the phone slower since upgrading to Android 6!? I thought it should bring a performance improvement!?
Should I wipe the phone via factory restore or what else can I try / check?
Thanks
SnuffThePunkz
Re: Android 6 upgrade - phone seems slower than before?
Wed May 18, 2016 6:02 am
It was incredibly slow till I installed my apps that clean up memory and space. A fresh install is the way to go for sure.
decayedsin
Wed May 18, 2016 6:52 am
Yeap, I also noticed it ( besides having antenna issues on mine). I have use OTA, Download and "Flash and Download", and it always was heavy and slow on mine. I am back to version 1.5.
Wed May 18, 2016 10:06 am
steirx wrote:
Hi there,
Thanks
we feel so sorry about this problem. Because the new rom file is larger,
so after update, the device may work a bit slow.
Best regards,
Admin
borys42
Wed May 18, 2016 11:00 am
How to downgrade soft ? before update a battery operated about 3-4 days at full load ( camera , BT , WIFI , @ , conversations and messages ) At present, the rate of decline percentage for the battery is more or less an 1 % per minute due to a fucking shit 6.0 android ...
Enybody can help ?
hori
Wed May 18, 2016 12:31 pm
Hi guys hope someone can help.I upgraded to 6.0 via ota but the phone wont boot it just has the blavkview logo.I only get three options in recovery mode Normal, Fast boot and recovery which comes up with dead droid and says no command.Am trying to reflash it via the tutorial here but
i cant get past the first stage.The computer fails to load the software correctly and i get my device not recognised properly.Very frustrating
nbk333
Wed May 18, 2016 1:23 pm
This morning lefrissült phone on Android 6.0. Since then, more than two minutes to turn on. Very slowly, the two do not go sim usual. I can not make phone calls on the second sim card. The battery is also very exhausted. Applications stop error. How do I return to Android 5.1? Where can I download it? I ask for help because the phone is so useless.
Peter
AustrailianBlackview
Wed May 18, 2016 4:02 pm
My device is also painfully slow and wont charge.
How do i roll back to the previous version?
I cannot use this phone anymore and it is only one month old.
skulhedface
Wed May 18, 2016 4:15 pm
Dear Admin, the phone is not "a bit slow". It's a difference like day and night.
Now I'm stuck with a battery that won't charge over 45%. I tried everything - different cable, charger, charging while off - nothing works. It just won't charge up over 45% and it takes ages to even reach that (trickle charging?). :(
At least this time there's no hidden malware in the OS. :lol:
Sword76
Wed May 18, 2016 4:28 pm
Dear Sirs!
Is it possible to roll back to Android 5? It was my big mistake to update my hv5000 to 6.0. And your answer makes me feel that we should live with slow device because of big image. Next update may solve this issue or may be not. I was quite happy with latest Android 5. And I would like to downgrade to old version. Is it possible to download old image? Thank you.
