akalaszi
Tap&Pay is not working
Thu Aug 03, 2017 5:31 pm
Hi Admin,
On my BV8000Pro the NFC is working: I can read my credit card history.
The mobile payment app of my bank is failing: They said that they are using mastercard api for the card transactions and it should be compatible.
This payment app requires Android 4.4 and up even though it sees the BV rom invalid.
1. NFC is enabled
2. Tap&Pay is enabled
3. BV8000Pro-Blackview-V0.1_20170718_20170718-1901
4. developer mode disabled
4. https://play.google.com/store/apps/deta ... mkb.mkbpay
5. Error message after starting the app:
Threat detected
Invalid rom was detected on your device. Application will close after click OK.
Is there any setting that I can set to make the Blackview rom valid for MasterCard payments?
Thanks,
Adrian
Users browsing this forum: Google Adsense [Bot] and 2 guests
