Jomas
[SOLVED] Sound/speaker problem with blackview bv8000 pro
Wed Aug 02, 2017 8:29 pm
Hello!
Yesterday i received my brand new blackview bv8000 pro. But there is issues with the loudspeaker. There is no sound att all from it from music player, alarm, phone call signal and so on. The only sound from loudspeaker is when i pick upp a call or make an call. There is coming sound from bluetooth speaker if I choose to use that. Sound works as it should with the "ear speaker" that came with the phone. The "Do not disturb" function is NOT activated ( check several times and the phone vibrate when alarm clock goes on but no sound). I had tried factory reset and i have the the BV8000Pro-Blackview-V0.1_20170718. Any help is highly appreciated.
Re: Sound/speaker problem with blackview bv8000 pro
Thu Aug 03, 2017 10:19 am
If nothing helps please ask your seller for a exchange.
Jomas
Thu Aug 03, 2017 2:06 pm
I had contact the seller by mail about the problem and waiting for answer. I'll let you know the answer/soultion. Thanks.
Wagner
Mon Aug 28, 2017 3:48 pm
Jonas, hard reset you device, it shoud do.
I just got my bv8000 pro with the same issue, after hard reset, it is all good.
https://www.mobileheadlines.net/blackvi ... ard-reset/
ivanot
Tue Nov 14, 2017 3:51 pm
I have a different problem with the speaker, the same stated in this video:
https://www.youtube.com/watch?v=PHYpo6uPvBI
Solutions?
Sun Dec 03, 2017 2:54 pm
Solutions?
It looks like an hardware fault. If updating to latest firmware + factory reset doesn't solve the issue, please contact your seller for a replacement under warranty.
ivanot
Tue Dec 05, 2017 2:57 pm
I can now confirm that my hardware is broken, so I have to rpalce it.
Is there a quick way to buy a replacement? I'm skilled enough to replace it. Please give me some info, even in PM if not permitted by forum policies.
Ciao
Ivano
Tue Dec 05, 2017 3:42 pm
Ciao
Ivano
This is the "quickest" and cheapest way:
https://www.aliexpress.com/item/ocolor- ... eLevelAB=3
Users browsing this forum: Google Adsense [Bot] and 2 guests
