marcos595
after upgrade Android 7.0
Wed Aug 02, 2017 11:05 am
Hi everyone today I've upgraded to Android 7.0 when I restart my phone the google play app and other apps go in continual crash some that has the same problem could indicate if there is a solution? thank you all
Re: after upgrade Android 7.0
Wed Aug 02, 2017 11:26 am
update to the latest Firmware and perform a factory reset in recovery after that.
marcos595
Thu Aug 03, 2017 8:20 am
First of all thank you for the quick response, yesterday I followed your directions but did not work then I decided to install the twrp recovery and make a new flash of the rom not check the file recovery magically the phone has resumed to work but the Recovery twrp has also been replaced by the original. At the moment I try android 7.0, but already know some bugs like this does not keep the ringtone after rebooting. thanks for collaboration
