omegasportz
flashed new version 20170719
Tue Aug 01, 2017 7:22 pm
hello i got a verry seriours problem. \when i flashed rom i cant see launcher and gapps .. please can you help me how to fix this problem
Re: flashed new version 20170719
Wed Aug 02, 2017 11:36 am
please reflash and perform a factory reset in recovery after that.
