kotsu
Camera Front-to-Back Switch Option is not available
Fri Jan 01, 2016 11:05 pm
I just received phone yesterday and noticed, when I launch the Camera app then by default the front camera is active and the picture appears on screen upside-down. Camera front-to-back switch option is not appearing on the screen at all, so I'm not able to use the back camera.
I've reset phone to factory settings, also rebooted in safe mode, but it is still the same.
Is there fix to this issue?
Re: Camera Front-to-Back Switch Option is not available
Mon Jan 04, 2016 7:40 am
hi,
You can find the seller to solve a solution first, it will be quicker to find and solve your problem .
Best regards,
Admin
