Onyeredson
Negative picture Screen
Tue Aug 01, 2017 2:20 pm
Good day, I hope my message finds you well? I'm very frustrated an upset with my new BV8000pro. My old BV5000 suffers severe flickering on screen so I thought upgrade. Out of the box and the first thing I try is the 16mp rear camera and the picture is Awful. It is as a Negative White is Black and vice versa. I thought camera fault but when I view pictures taken on Pc theyr'e fine. I've tried adjusting allsorts of things in the Miravision settings and no change. I downloaded system update and still no difference. Can anyone help please? 5 mails sent to BV H.K. and no response so what do I do now? I can't go on Facebook as all pictures terrible, I can't see pictures sent from friends and relations. What's the point of paying good money for a phone with no back up plus when out of the box having serious faults.
Re: Negative picture Screen
Thu Aug 03, 2017 10:35 am
update to the latest Firmware and perform a factory reset in recovery after that.
Please provide pictures to show your problem. Do you use facebook app or browser?
