maykelvitor
Bv7000 Pro is not receiving calls.
Tue Aug 01, 2017 1:58 pm
Hello
I made the purchase and it took a month for the smartphone to arrive. He arrived at my residence yesterday.
Bv7000 Pro is not receiving calls. But He is making calls.
Sometimes he gets a quick call. But it is not possible to answer. Soon after he does not receive any more calls.
This was the only problem encountered so far.
I would like a solution.
It is in the factory version. Not yet updated. And for me to have no more problems, I'd rather leave it that way.
I wish you would help me. Well, I really liked the product.
Thank you.
Re: Bv7000 Pro is not receiving calls.
Mon Aug 07, 2017 8:34 pm
update to the latest Firmware and perform a factory reset in recovery after that.
