marinkolesh
Problem with staying connected to any network
Tue Aug 01, 2017 12:35 pm
I have bought my father BV6000 and the phone is great for his use, but it has one problem. Every time I connect to a network (WiFi or mobile network) it connects, works for 10 sec, and the it disconnects. It is very annoying, and it means he can't use any network. Is there a fix for this problem?
Re: Problem with staying connected to any network
Tue Aug 01, 2017 3:22 pm
1) Please check if you have activated any battery saving mode
2) Go to Wifi settings ans check that "keep Wi-Fi on during sleep" is set to "always"
3) update to the latest Firmware and perform a factory reset in recovery after that.
