Thu Aug 10, 2017 6:49 pm
			A) If you are in Boot mode you can select recovery, fastboot or normal. You can use the volume-up-key to move the selection and the volume-down key to confirm. Select "Normal" and confirm.
B) If you see an open android with "no command" press vol-up and power to enter recovery
C) If you are in recovery mode you can select by vol-up and vol-down and confirm by power. Select reboot to restart.
