Matioupi
[SOLVED] USB type C cables and accessories
Tue Aug 01, 2017 9:36 am
I just own a new bv8000 pro. It's a nice piece of hardware so far.
I have one main issue right now : finding compatible cables and accesories.
I have the one that were provided in the package, but I'd like to buy extra cable USB 3 type A to USB type C cables for the car and office. I also would like to buy another type C to micro B adapter for putting in my drone toolbox.
I tried regular items and they do not fit. I guess this is because of the IP68 capability.
So question is simple : where can I buy bv8000 pro compatible cables and adapter ?
Best regards
Re: USB type C cables and accessories
Thu Aug 03, 2017 10:37 am
BJSr
Sat Aug 05, 2017 7:12 pm
Hi.
1. Buy an USB Type C to USB A Cable.
2. Trim off the connector C about 2mm from the insulation sleeve to comply with the BV8000 PRO standard.
3. Thats it, it works!
regards
Matioupi
Mon Aug 21, 2017 3:20 pm
blackview_admin wrote:
done for the cables (altough I would have prefer to buy through Amazon than aliexpress...)
do you have a similar link for the type C to micro B adapter ? I'd like to get an extra one to keep with my drone stuffs...
Matioupi
Fri Aug 25, 2017 6:43 pm
no shopping link for some extra tiny USB C to USB micro B adapter ?
Mon Aug 28, 2017 2:43 pm
sorry, I don't have such an amazon link
